Why is my iPad So Slow and Lagging? 12 Ways to Speed Up an iPad
ipad is very slow
“Why is my iPad so slow?” If your iPad is very slow, it’s a sure sign that something isn’t working the way it should. Unfortunately, there are a lot of “somethings” to consider. Your iPad’s performance issues may be caused by your battery, iOS version, storage, and a host of other factors.
But here’s the silver lining – once you know what caused the slowdown, fixing it is straightforward. In this article, we’ll break down all the possible reasons why your iPad is running slow as well as their exact solutions. Read on!
Why is My iPad Running Slow?
There are many possible reasons why your iPad is slow. It’s important to pinpoint the exact cause because each issue has a specific solution. To help you quickly figure out the problem and jump to the correct solution, we prepared a detailed menu:
Cause Summary & Solution
📲 Background apps are taking up resources The iPad needs enough memory to run optimally. Even if you swiped out of your apps, it’s possible that they are still running in the background and taking up precious memory. Solutions: Method 1, Method 2
🪫 Battery Saving Mode is on Battery Saving mode is a feature on the iPad that tells the device to reduce its power usage. You may notice lower screen brightness, lack of visual effects, and overall reduced performance (among other optimizations). Solution: Method 4
⚙️ Your iPad’s Software is outdated If your iPad’s iOS or certain app is outdated, you aren’t getting an optimized experience. You may also encounter security vulnerabilities and compatibility issues that can further impact your device’s performance. Solution: Method 5
🌐 Internet is slow or unstable If your iPad downloading is slow or your device is slow on WiFi, there’s likely an issue with your network. It may also affect your iPad’s performance indirectly because certain apps (and the device itself) keep trying to reconnect to the internet in the background. Solution: Method 6
🗄️ The iPad’s storage is full If your iPad’s storage is full, it won’t be able to save cache data, which are temporary files that your device uses to launch apps and execute other functions faster. Solution: Method 7
📟 iPad settings are unoptimized Low touch screen sensitivity, Low Power Mode or motion settings may cause the iPad to feel slow and laggy. Solution: Method 8
How to Conduct iPad Performance Test
If you know your way around your device, you can also figure out why your iPad is running slow and freezing by monitoring your device’s different components.
In other words, you will want to check out your battery, memory, network, storage, and processor speed, among other things. While you can do it manually by seeking out their respective menus one by one, we suggest using the following apps from the App Store:
  • AnTuTu Benchmark. AnTuTu Benchmark is a popular and intelligent app that not only collects your iPad’s performance data, it analyzes it for you as well. It will score your device’s performance (against a benchmark), test your iPad storage’s reading and writing speed, measure your network speed, and more.
  • System Status Pro: hw monitor. System Status Pro provides in-depth information about your device. It lacks the “scoring system” of AnTuTu Benchmark, but you will know everything about your iPad’s battery, disk, network, CPU, and hardware information. It also provides resource graphs that can record your iPad’s memory consumption during up to 3 minutes of background activity. Here’s the free version.
  • Battery Testing. Unlike the other 2 suggestions, the Battery Testing app gives you a ton of data about just your iPad battery. Battery Testing can monitor battery health and track its current raw data (like voltages and charge cycles). It can also monitor your device’s runtimes, which tracks how long your iPad’s battery lasts. This is a handy tool to monitor your battery’s performance over time.
How to Speed Up a Slow iPad
In this section, we provide you with step-by-step instructions for different methods to fix a slow iPad. These methods solve specific problems that may have caused the reduced performance. It’s important to use the correct method for your device’s issues.
These methods work for the iPad, iPad Mini, iPad Pro, and iPad Air. They may also make an old iPad faster (except for updating your iOS if your iPad is really old).
Method 1: Force Quit Applications
Even when you exit your apps by returning to the home screen, they are still running to some extent in the background.
To force quit running apps, swipe up from the bottom of your screen and pause for a second until you see snapshots of all previously opened apps. This feature is called the App Switcher.
App Switcher feature on the iPad
You can swipe left and right to browse and swipe up to force quit the app.
Method 2: Reboot Your iPad
Some apps continue running in the background even if you force quit them via the App Switcher. Rebooting your iPad will shut down all running processes and clear out its memory.
To reboot your iPad:
Settings app on the iPad
Step 2. On the left sidebar, tap General. Then, scroll down on the right pane and tap Shut Down.
Shut Down option in the iPad's Settings app
Step 3. Drag the slider all the way to the right to confirm shutdown.
Power slider on the iPad
Wait for your iPad screen to go completely black. Then, turn it back on by pressing and holding the power button until you see the Apple logo.
Method 3: Remove Big Files
A full storage can no longer accommodate new cache files. We need to make room for the cache data in order to improve device performance. In other words, we need to free more storage and clean up the iPad to run faster.
Consider deleting apps, photos, videos, and other data you don’t need anymore. You can also use iCloud to save high-resolution copies of your photos online and keep smaller copies on your iPad.
If you take a lot of pictures and videos or use your iPad for heavy gaming or work, it may be worth looking at iCloud’s paid plans, which can provide up to 2 TB of cloud storage.
Here are some easy deletion tasks to get started:
  • Delete large photos and videos. In the Photos app, delete unnecessary files from the Videos, Bursts, and Live albums. Those are usually the biggest. You can also use a third-party cleaner app to quickly and easily delete duplicates, large files, and other library clutter. We recommend Clever Cleaner, a 100% free app that automatically compiles your largest photos and videos, as well as junk files (like blurry or similar photos) for easy deletion.
  • Erase large attachments. If you send or receive media attachments via the Messages app, those get saved to your iPad’s local storage. You can delete them by opening any message in the Messages app and tapping their contact photo at the top of the conversation thread. All attachments sent between you and this contact will be compiled here, sorted by size, and ready for your review.
  • Remove or Offload unnecessary apps. Open Settings > General > iPhone Storage and arrange the list of apps by size. Tap on the largest app you want to delete. Then, tap Delete App to remove it completely or Offload App to uninstall the app itself but keep the app data.
  • Delete any media app downloads. Delete downloaded movies, songs, and other media from their respective apps (e.g. Netflix, Spotify, YouTube Premium).
Method 4: Turn Off Battery Saving Mode
As we previously mentioned, Battery Saving Mode is a feature on the iPad that limits certain functions to conserve power. This includes reducing the iPad’s CPU clock speed, which saves power but it’s likely why your iPad is slowing down.
To turn off Battery Saving Mode:
Step 1. Open the Settings app.
Step 2. On the left sidebar, tap Battery. Then, toggle the switch next to Low Power Mode (it will turn gray).
Low Power Mode in iPad's battery settings
Method 5: Update Your Software
Updating your operating system and application software may help speed up your iPad. If the problem is affecting general iPad performance, start by searching for iPadOS updates. Go to Settings > General  > Software Update and follow the on-screen instructions if an update is available.
If the problem seems to affect a specific app or only occurs when that app is running, you should update to the app’s latest version. Go to the App Store and see if there are updates for the app. If an update is available, install it and try using the app again.
If you are still experiencing poor performance after updating your software, wait for about 30 minutes and reboot the iPad. New updates may take a while to fully integrate with the system and may be adjusting to the power demands of the new features. A reboot allows a fresh restart.
Method 6: Check Your Internet Connection
Your iPad may be running slowly due to an unstable or poor Internet connection. This can be caused by a wide variety of problems that you need to address methodically to fix the issue. Try the following steps to verify you have a suitable Internet connection.
  • Make sure your router is properly located in range of your iPad and that all cables are connected securely.
  • Use a third-party tool such as SpeedTest to test your current network speed.
  • Manually reconnect your iPad to the network. Go to Settings > Wi-Fi to see your network connection. If alternate networks are available, you can try connecting to one of them and see if performance is better. You can also use the Forget This Network feature to remove a network and its configuration details from the iPad. This may clear up authentication issues that are slowing down your device’s performance.
Network settings icon on the iPad
Method 7: Clean Your iPad’s Caches
Cache data accumulates over time and may even get corrupted. Both issues may impact your iPad’s performance; a full storage will have no room for new cache files, while corrupted cache data can cause your iPad to run slowly or even crash.
Fortunately, we can manually clear cache data ourselves. Below, we’ll show you how to clear your browser and app cache data.
This is a good method to try if your old iPad is slow. Older iPads tend to have a lot more data accumulated in storage.
To clear Safari’s browser cache on your iPad:
Step 2. Tap Safari (you might have to scroll down a bit). Then, tap Clear History and Website Data on the right pane.
iPad Safari history settings
Step 3. Tap Clear to confirm the action.
iPad clear history dialogue
To clear Google Chrome’s browser cache on your iPad:
Step 1. Open the Google Chrome app.
Google Chrome app on iPad
Step 2. Tap the 3 dots on the bottom of the screen.
Settings button in the Google Chrome app on iPad
Step 3. Tap History.
History button in the iPad Chrome app's settings
Step 4. Tap Clear Browsing Data.
Clear browsing data button in the iPad's Google app's settings
Step 5. Adjust the time range to set how far back you want to clear your data. Then, make sure the following options are selected: Cookies, Site Data and Cached Images and Files. Finally, click Clear Browsing Data and confirm when asked.
Clear Data settings on the iPad's Chrome app
To clear app caches on your iPad:
Step 2. Tap on the app you want to clean.
Step 3. Tap Clear Cache.
For users running iOS 13 and above, you may not have the option to clear your app caches. With the latest iOS versions, Apple has introduced more resource management functionality and the device should automatically clear cache data on its own.
Method 8: Adjust Your iPad Settings
Your iPad is a very customizable device with many settings that can be tweaked to improve a slow-performing device. Check the following settings
  • Battery > Low Power Mode – Running in low power mode will slow you down as the device strives to conserve energy.Low Power Mode
  • Go to Settings > Accessibility > Touch > Haptic Touch to adjust screen sensitivity which may allow for faster navigation.iPad Hold Duration settings
  • Motion settings can be modified by going to Settings > Accessibility > Motion. Reducing Motion may help speed up your iPad.adjust motion settings
  • Reduce the Transparency effect by going to Settings > Accessibility > Display & Text Size and turning on the Reduce Transparency option.reduce transparency
Method 9: Disable Background App Refresh
Background App Refresh is a setting on iOS. When enabled, your apps are given permission to update their content in the background. While this is meant to help your iPad’s overall performance, it can inadvertently cause your device to slow down due to all the updates constantly happening in the background.
Step 1. Open the Settings app, then tap General. On the right pane, tap Background App Refresh.
Background App Refresh option in the iPad Settings app
Step 2. To disable the setting for ALL apps (to immediately free up as much memory as possible), switch the toggle beside Background App Refresh to the OFF position – it should turn grey. If you leave the setting on, you will have the option to disable it for individual apps instead.
Background App Refresh Settings for iPad
Method 10: Remove Widgets
iOS widgets always take up at least a bit of memory when they are added to your screens. Almost all widgets run in the background in order to update the displayed information in real time. Many of them even have to download that information beforehand (e.g. weather).
While most widgets are optimally coded to use up as little memory as possible, they still add up over time.
Step 1. Navigate to your iPad’s home screen and locate your widgets.
Step 2. Tap and hold the widget or stack you want to remove. Then, tap Remove Widget or Remove Stack.
Remove Widget button in the iPad homescreen
Step 3. When prompted, tap Remove again to confirm the action.
Remove Widget confirmation popup
Method 11: Reset Your iPad Settings
While not super common – especially for iOS – it’s possible that your iPad’s settings have somehow resulted in incompatibility, bugs, or network issues. Fortunately, you can easily reset all the settings on your iPad to their default without having to delete any apps or data.
Step 1. Open the settings app and tap General. Scroll down to the bottom of the menu and tap Transfer or Reset iPad.
Transfer or Reset iPad button in General Settings
Step 2. Tap Reset. In the menu that pops up, tap Reset All Settings.
Reset All Settings button in iPad Settings
Method 12: Factory Reset Your iPad
If resetting all settings didn’t work – and nor did any of the solutions – your last resort is to perform a Factory Reset on your iPad.
Unlike the last method, a Factory Reset not only resets your settings but also completely wipes any app and user data on the device. So if you have any problematic files causing the slowdown (due to bugs, corruption, etc.), this method should resolve them all at once.
If you plan on performing a factory reset on your iPad, make sure to create several backups of your data to avoid accidental data loss.
Step 2. Tap Erase All Content and Settings.
Erase All Content and Settings button
Step 3. Tap Continue to confirm and proceed with the reset.
Factory Reset wizard for iPad
iPads (especially the newer ones) are pretty good at self-maintenance. However, they are still vulnerable to performance issues that can be caused by many different factors. Fortunately, almost all scenarios where the iPad is loading slow have exact solutions that we can do ourselves.
To prevent performance issues in the future, keep your iPad’s iOS updated, take care of your battery, maintain your storage, and use a strong internet connection.
Here are possible reasons why your iPad Air is taking so long to turn on:
  • Full storage – If you have a lot of data on your iPad Air, it has to load everything into memory so you can easily access them later.
  • Low battery – Your iPad Air may be struggling to get enough power to turn on immediately.
  • iOS or app issues – If there are software issues on your device, your iPad Air will try to resolve them as it starts up. Bugs may also be causing problems during the startup process.
To clean up your iPad Mini to make it faster, try these tips:
  • Delete apps and files that you no longer need.
  • Delete glitchy and unstable apps.
  • Clear your browser cache (Settings app > Safari) or (Google Chrome app > 3 dots > History).
  • Clear your app caches (Settings > app you want to clear).
There are 2 possible reasons why your iPad Pro is taking so long to update:
  • Low storage space – Your iPad Pro is struggling to find enough space for the files it needs to install the update. Delete large apps and files you no longer need or upload them to iCloud.
  • Poor internet connection – Your iPad Pro needs to download the update package from the internet before installing it. Considering that iOS 16 is around 3-5 GB, you need a fast and stable internet connection.
Here are possible reasons why your iPad is charging extremely slow:
  • Your charging cable or adaptor is damaged, not properly connected, or isn’t an original Apple accessory.
  • You are charging from a low-power source such as a USB port on a computer or a low-output adapter.
  • You are using resource-heavy apps (like video games) while charging your iPad.
  • Your iPad’s battery health is low due to damage or natural wear.
Chief Writer
Robert Agar is a technical writer with over thirty years of IT experience. He specializes in topics like data recovery, security, and regulatory compliance. Armed with a bachelor's degree in computer science from Pace University, New York, Robert shares his… Full Bio
