How to Delete Photos from iPhone but Keep Them in iCloud
how to delete photos from iphone but not icloud
Want to know how to delete photos from your iPhone but not iCloud? It’s a good way to clean up your local storage space and secure your iPhone (in case you want to sell it or give it away) without actually losing your data.
There are different methods to achieve this result along with a few non-iCloud solutions if you’re willing to compromise a bit. This article covers them all… And both iPhone users and iPad users can follow along. Read on!
Does Deleting Photos from iPhone Also Delete Them from iCloud?
Deleting a photo from your iPhone will only be deleted from iCloud if a specific setting is enabled. This setting is called Sync this iPhone.
When enabled, all changes to your photo library are mirrored to iCloud—including adding and deleting photos. These changes are also reflected in your other devices that have iCloud and Sync this iPhone enabled.
This section assumes that iCloud is enabled on your device in the first place. In other words, you have to enable iCloud, THEN enable the sync settings. Go to: Settings app (Apple ID > iCloud > Photos > Sync this iPhone). See the next section for a more detailed guide with screenshots.
Here’s a simple table to help you remember more easily:
Setting Effect
Sync this iPhone is turned ON for photos Deleting a photo locally will also delete it from iCloud. All changes in your library will be reflected.
Sync this iPhone is turned OFF for photos Deleting a photo locally will not delete it from iCloud. No changes in your library will be reflected.
iCloud sync can also possibly cause data to be duplicated in case of bugs or an unstable network. Make sure you delete all duplicates on your iPhone before enabling or disabling iCloud sync to prevent duplicates from getting carried over.
How to Delete Photos from iPhone but Not iCloud
So we know that iCloud sync causes changes to your device to be mirrored to the cloud. Now, the goal is to either (1) prevent this synchronization from happening so you can remove photos from your iPhone but not iCloud or (2) store your data in another location so your photos remain secure regardless of your iCloud settings.
We’ll show you 6 different methods of applying these solutions in the sections below.
If your goal is to free up space on your iPhone by cleaning up your local library, don’t forget to delete your photo clutter as well. Similar photos, duplicates, old screenshots, and other “junk” library items can take up gigabytes of space over time. We recommend using third-party apps for faster and more efficient cleanup (try Clever Cleaner, which is completely free–no trials, no “premium version”, and no ads).
Method 1: Turn Off iCloud Sync for Photos
The most straightforward way to delete pictures from your iPhone but not iCloud is to disable iCloud sync for your Photos app. Once this setting is disabled, the connection is severed and changes on your iPhone will no longer be synchronized to the cloud.
To turn off iCloud sync on your iPhone and keep your photos in iCloud:
Step 1. Open the Settings app and tap on your Apple ID. Then, tap iCloud.
Step 2. Tap Photos.
Step 3. Disable the Sync this iPhone setting.
Enabling iCloud Sync for Photos on an iPhone
Once iCloud sync is disabled, you can freely delete photos from your library without worrying about affecting your iCloud data in any way.
Method 2: Sign In to Another iCloud Account
Another way to cut the link between your iPhone and your iCloud (thus preventing changes to your device from being reflected in the cloud) is by signing in to a different iCloud account.
When you sign in to a different iCloud account on your iPhone, changes on your device will no longer carry over to your iCloud. It won’t be reflected in the new account either, because the sync feature is tied to the iCloud account associated with your device.
In other words, sign in to a different iCloud account and delete without worry!
To sign in to another account on your iPhone:
Step 2. Scroll down to the bottom of the page and tap Sign Out.
Step 3. Select the data you want to keep on your iPhone. Then, tap Sign Out in the top-right corner of the screen.
Signing out of Apple ID on an iPhone
Once you’ve signed out of your iCloud account, you’ll be prompted to sign in again. You should now be able to delete photos from your iPhone without affecting your own iCloud data.
Method 3: Enable Optimize iPhone Storage
The Optimize iPhone Storage feature is a setting that can help you save a lot of storage space by only keeping low-resolution versions of your photos on your device. The original high-resolution copies are then stored in iCloud.
The bonus side effect of this setting is that you can freely delete the low-res images on your iPhone’s Photos app without affecting their original versions in iCloud.
To enable Optimize iPhone Storage on your device:
Step 1. Open the Settings app and tap your Apple ID. Then, tap iCloud.
Step 2. Tap Photos.
Step 2. Enable Optimize iPhone Storage.
Enabling the Optimize this iPhone setting for iCloud Sync for Photos
Give your device a few minutes to adjust to this new setting. Then, check if your photos have been uploaded to iCloud.
Method 4: Backup Your Photos to Google Photos
Are you open to using other cloud services? Because Google Photos provides a super useful tool that allows you to import a complete copy of your iCloud photos.
This method will allow you to purge your local photos without being overly cautious. Having a second backup copy of your data is also always a good idea in our book.
To copy your iCloud photos to Google Photos:
Step 1. Login to privacy.apple.com
Step 2. Tap Request to transfer a copy of your data.
Step 3. Scroll down to the bottom of the page and tap on the Select Destination dropdown menu.
Initiating a Data Copy Request on the Apple website
Step 4. Select Google Photos and choose the data you want to transfer. Then, tap Continue.
Step 5. Read the notice, then scroll down and tap Continue.
Choosing parameters and confirming Data Copy Request on the Apple website
You will then be prompted to login to your Google account. Once you’ve signed in, your photos will appear in Google Photos in 3-7 days. After which, you can safely delete your photos from your iPhone without deleting them from iCloud.
Once you’ve deleted your photos, make sure that you don’t enable iCloud sync for your Photo Library!
Method 5: Copy Photos to an External Device Using Mac
If you don’t want to use another cloud service, why not copy your iCloud photos to an external drive? This way, you have an offline copy of your data you can access and/or modify anytime without worrying about network-related issues like login and synchronization.
Fortunately, it’s super easy to copy your iCloud photos to your Mac or to an external drive. You don’t even need to connect your iPhone to your computer with a cable. You just need the Mac Photos app and a stable network.
To copy iCloud photos to an external drive using Mac:
Step 1. On your Mac, open the Photos app (Finder > Applications).Photos Application in FInder
Step 2. Open your Library or any album. Then, click on any photo to select it. Alternatively, hit CMD + click to select multiple or CMD + A to select all. Then, drag your selection to any location on your Mac (you can either copy them directly to your external drive’s directory or copy them to your Mac’s local disk first).Select All in Photos
Method 6: Use Third-Party Apps
Google Photos is not the only cloud-based backup/storage service. There are quite a few, in fact. To help you, we came up with 3 recommendations that satisfied the following simple criteria:
  1. You don’t have to manually upload your photos
  2. It offers at least limited free storage space so you can try it out without buying
Here are our app recommendations:
  • Dropbox Provides 2 GB of free storage space. It’s not a lot but Dropbox is well-known and commonly used in professional spaces. Files saved in Dropbox can also be seamlessly accessed and used in Dropbox Paper.
  • Microsoft OneDrive Provides 5 GB of free storage space. Like Dropbox, OneDrive is well-known and used by professionals. It’s a great option for users of Microsoft Office.
  • Terabox: 1024GB Cloud Storage TeraBox is not as well-known as Dropbox and OneDrive. The free version also has a lot of ads… But you truly get 1,024 GB (1 TB) of free storage space.
How to Delete Photos from iPad but not iCloud
The concept of iCloud synchronization is the same on the iPad as with the iPhone. With that in mind, the methods to delete iPad photos without affecting iCloud data are:
Trouble Deleting Photos?
Are you having issues with properly deleting your photos? Maybe the deleted photos keep coming back, or the sync settings aren’t working as they should. This can sometimes happen due to software bugs or network interruptions.
To help our readers with this issue, we wrote a guide on how to delete all photos from an iPhone, with a section covering potential reasons why you’re unable to delete your photos (and what to do about it).
To move selected photos from iPhone to iCloud storage and delete them from iPhone, use one of these 2 methods:
  1. Turn off iCloud sync. Then, manually save photos to iCloud and delete them from your iPhone.
  2. Enable iCloud sync for your photos and enable the Optimize iPhone Storage setting (Settings app > Photos). You can then delete the low-res copies of your photos on your iPhone without affecting their original copies in iCloud.
To keep photos on iCloud only, disable iCloud sync for your photos (Settings app > Apple ID > iCloud > Photos). Then, manually move your photos from your iPhone to your iCloud storage via iCloud.com. Alternatively, you can enable Optimize iPhone Storage (Settings app > Photos). With this setting enabled, you can delete all photos from your iPhone but not the cloud.
To delete photos from your iPhone synced to your Mac, ensure that iCloud sync is ENABLED for your photos (Settings app > Apple ID > iCloud > Photos). Then, you can delete your photos on your iPhone or on your Mac and the changes will be reflected on all of your devices.
Chief Writer
