Duplicate Photos are Not Showing Up in iOS: How to Fix
ios 16 duplicate photos not showing
Are duplicates not showing up on your iPhone? iOS (and iPadOS) is able to detect duplicates automatically, which it then compiles for easy cleanup. However, there are cases where it fails–due to bugs, glitches, or simply because your photos aren’t “exact” duplicates (more on this later).
If you find identical photos in your library and iOS isn’t notifying you of duplicates, this article is for you. In this guide, we’ll break down how duplicate detection works on iOS, why it may not be working on your device, and how to fix it.
What is Duplicates Album in iOS
The Duplicates Album is an iOS-generated album you can find in the Utilities section of the Photos app. It uses a special algorithm to identify duplicate photos in your library and compiles them for you in one place.
It comes with the Merge tool, which you can use to automatically delete all duplicate photos (in a set) except for the best copy.
The Duplicates Album was first introduced in iOS 16 and remained a staple feature in future iOS versions. We’ll show you how it works:
Step 1. Open the Photos app and tap Albums at the bottom of the screen. Then, scroll down to the UTILITIES section and tap Duplicates. You may have to provide your Face ID, Touch ID, or password to access the album.
Step 2. On this screen, duplicates will be grouped together. You can tap the Merge button in each cluster to combine all photos in the group into one high-quality picture.
Step 3. Tap Merge again to confirm the action.
Merging duplicate photos in the iOS Photos app
If you don’t need the original photo at all, you can also delete clusters from the Duplicates album by tapping Select > select cluster of duplicates > Trash icon.
Why are Duplicate Photos Not Showing Up on My iPhone?
For iOS to see duplicate photos on your iPhone, it first has to index your photo library. In other words, it has to create an updated database of all of your photos and videos.
Once your library is indexed, iOS will begin hunting for duplicates. This stage will only happen under 2 conditions: (1) your iPhone needs to be locked and (2) connected to a power source.
Either process may be disrupted, preventing duplicates from being cataloged in the Duplicates album. Here are common reasons why this happens:
Reason Summary
🔔 Your device is not updated to iOS 16. Double-check if you’re really on iOS 16 (Settings app > General > Software Update)! The Duplicates album was only released during this update.
🚫 You have no duplicate photos. You may not actually have any duplicates at all OR you have identical photos that iOS does not consider as “duplicates.” For the latter, read this section of the article.
🗄️ You don’t have enough storage space. iOS needs ample storage space (likely for cache or temp data) in order to perform the indexing process. If you have little storage, iOS may struggle or even fail to index your photo library and won’t be able to start looking for duplicates. Make sure to clean up your iPhone’s storage if your Duplicates aren’t appearing.
📱 Apps or processes are running in the background. As previously mentioned, iOS can only find duplicates when your device is locked and plugged into a power source. If you (or a background process or app) keep using your iPhone, both duplicate detection and indexing may get delayed.
🕷️ There are software bugs or glitches on your device. Bugs or glitches may also affect the indexing process, preventing iOS from finding duplicates. If the album for duplicate photos is not working, try restarting your iPhone and removing sketchy apps. Check if there are any updates available.
🖼️ There are corrupted photos or videos in your library. If there are corrupted photos or videos in your library, they may cause the indexing process to stall or fail (and prevent iOS from finding duplicates in the process).
🧩 Third-party apps are disrupting indexing. If you have third-party apps that directly interact with or affect your library, they may be blocking iOS from indexing it.
How to Fix Duplicate Photos Not Showing on an iPhone
Let’s say you do have enough storage space you clearly have duplicate photos in your library, but the Duplicates album still doesn’t appear. While iOS tries to take care of everything automatically, there are a few methods you can use to attempt to fix the issue.
We provide step-by-step guides for each of them in the sections below.
Method 1: Close All Apps and Wait
As we described multiple times thus far, iOS’ duplicate detection feature works only AFTER your photo library has been indexed. Often, the Duplicates album takes a while to show up because iOS gets stuck in the indexing stage.
This usually happens when you add a lot of new photos to your library (iOS still has to work through them all) or if you only recently put your phone down and plugged it in.
Our suggestion? Just wait! Make sure you’ve closed all apps using the App Switcher and your iPhone is locked and connected to a power source. Then, leave it for 30 minutes to an hour (depending on how big your library is).
After some time, check if you can find the Duplicates album in the UTILITIES section on the albums page of your photos app.
Method 2: Reboot Your iPhone
It’s possible that your device has processes running in the background that can’t be exited using the App Switcher. In this case, it may be better to reboot your iPhone so it can index your library without having to compete with other processes for resources.
To reboot your iPhone:
Step 1. Open the Settings app and tap General.
Step 2. Scroll down to the very bottom of the page and tap Shut Down.
Step 3. Slide the power button icon to the right to proceed with the shutdown. When your device is fully powered down, press and hold the lock button until your iPhone starts back up.
Shutting down an iPhone using the Settings app
Once your iPhone has rebooted, unlock it so it can wake up fully. Then, lock the screen again, plug your device into a power source, and leave it alone for a while to avoid disturbing the indexing process.
Method 3: Update iOS
The Duplicates Album was introduced in iOS 16, so install it if you haven’t already—otherwise, the feature won’t be available to you. Even if you’ve already updated to iOS 16 (or later), there might be a newer version that addresses any bugs or glitches that may have prevented the duplicate detection feature from working on your device.
To update iOS:
Step 2. Tap Software Update. iOS will start checking for available updates. If any are found, download and install them.
Updating iOS via the Settings app
After updating iOS, it may take a while for the new features to be fully installed and former bugs and errors to be stamped out.
Method 4: Use a Duplicate Cleaner App
If updating iOS and rebooting your phone still doesn’t get rid of your duplicate photos, then they may not be considered as “exact duplicates” by the system. Even small changes in a media file’s data can prevent iOS from recognizing it.
In this case, we recommend using a third-party cleaner app. They utilize their own detection algorithms that may better suit your photo library in particular.
For this demo, we’ll be using Clever Cleaner: AI Cleanup App. It’s completely free with no ads and no premium-only limitations on features. Most importantly, its similar photo detection tool is accurate enough to be effective for cleanup, while being more flexible than iOS’ duplicate detection system.
Clever Cleaner also has other ways to help with library cleanup, such as compiling screenshots, large media items, and Live photos (where you can remove the video portion).
Step 1. Download Clever Cleaner: AI Cleanup App from the App Store. Then, open the app and give it access to your photo library.
Step 2. Tap the Similars option in the bottom menu. Then, tap on the collection of photos you want to review.
Step 3. Clever Cleaner automatically selects the best copy for you among the set, but you can manually select which photos you want to keep or delete. Once you’re satisfied with the selection, tap Move to Trash.
Step 4. A pop-up will appear at the bottom of the screen. Tap Empty Trash to confirm the deletion of the selected duplicates. You can also tap the pop-up itself (avoiding the Empty Trash button) if you want to review your deleted media items first.
Deleting similar photos using the Clever Cleaner iPhone app
Don’t worry! Even if you delete the media items from Trash, they will remain in your photo library’s Recently Deleted album for 30 days.
Method 5: Manually Create the Duplicates Album
You can also force the Photos app to find duplicates by manually duplicating an existing photo and leaving it to marinate while iOS indexes it. Fortunately, the Photos app provides the duplicate photo option directly from the camera roll (or a specific album). Just make sure to give your device enough time after duplicating the picture.
To manually force the Duplicates album to appear in Photos:
Step 1. Open the Photos app and navigate to your camera roll or any album.
Step 2. Tap on a random photo to view it. Then, tap on the menu button (3 dots) in the top-right corner of the screen and tap Duplicate.
Step 3. Confirm the photo was duplicated and lock your device. Then, connect it to a power source and leave it alone for 30 minutes to an hour so iOS has time to index your library and scan for duplicates.
Duplicating photos with the iOS Photos app
Method 6: Check Filters in the Duplicate Album
Your duplicate photos may be missing from the Duplicates album because its filter is set to only display videos. You can disable the filter so the album shows everything or you can choose to display only photos to make browsing easier.
To ensure that the Duplicates album is showing the correct media type:
Step 1. Open the Photos app and tap Albums. Then, scroll down to the UTILITIES section and tap Duplicates.
Step 2. Tap the filter button in the bottom left corner of the Duplicates Album.
Step 3. Tap All Items or Photos and tap Done in the top-right corner of the screen.
Choosing filters for duplicate photos in the iOS Photos app
Method 7: Uninstall Apps Associated With Your Photo Library
Do you have apps that interact with your photos? They may be obstructing the indexing process directly or running in the background, preventing the process from even starting.
We suggest uninstalling all photo and video-related apps (including editors) one by one until your Duplicates album appears. To do so, simply tap and hold the app to open a menu and select Remove app.
Make sure to back up any important data before deleting anything.
The Duplicates album is super useful but it’s still prone to glitches. Fortunately, there are ways you can help kick it back into gear without too much effort. However, note that it does have some weaknesses – namely, it can’t identify duplicates with certain variations. This is when an app comes in handy, but it stands to reason that Apple will iron out these kinks themselves soon enough.
Chief Writer
